Java mapscript in Windows
Jan Zich
jzich at EMORY.EDU
Mon Jul 17 19:59:19 EDT 2006
Hello,
I'm a beginner to MapServer and I'm struggling with MapScript Java API
in Windows. There seems to be something wrong with the naming of
functions in mapscript.dll and edu.umn.gis.mapscript.mapscriptJNI. It
seems that some functions are mapped correctly to their C equivalents,
but some not. For instance, the static method
edu.umn.gis.mapscript.mapscriptJNI.set_layerObj_name
should be mapped to (is that right?)
Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1name.
But there is no such function in mapscript.dll. Instead there is
_Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1name_1set
And, indeed, I get an exception
java.lang.UnsatisfiedLinkError: set_layerObj_name
On the other hand, mapscript_wrap.c seems to be correct since there is
Also, some methods seem to work. For instance, the following piece of
code works:
System.loadLibrary("mapscript");
mapObj map = new mapObj("test.map");
imageObj img = map.draw();
img.save("test.gif", map);
Is it possible that some files of some older version of MapScript were
mixed with a newer version?
Thank you
Jan
