calculate polygon area
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Jul 19 09:21:47 EDT 2006
Julien: The dev version of MapServer (which is quite stable) now has full support for GEOS operators in MapScript including a getArea() method. However, I don't know that Assefa has gotten around to adding them to PHP/MapScript. As far as I know the getArea method is planar...
There is a distanceToPoint method for point objects I believe but again it is doing a simple planar distance computation.
Steve
>>> Julien Bessiere <julien.63 at FREE.FR> 07/18/06 8:12 AM >>>
I'm using phpMapscript / Mapserver.
I wrote a little script that allows users to draw polygons on the map. I try to
figure out how to calculate the area of this polygon, but so far...
I found a formula and wrote the script below but as i'm using decimal latitude
and longitude, the result is unusable :
So my questions is :
1- Does phpmapscript has a function to calculate area
(something like distanceToPoint(pointObj poPoint))?
2- If no, how to calculate area wiht lat long coordinates?
thanks for your advices,
Julien
function polygonArea($polygon_coordinates){
$array_length = count($polygon_coordinates);
if ($array_length > 2){
// add the first coordinates at the end to close de polygon
array_push($polygon_coordinates,array($polygon_coordinates[0][0],$polygon_coordinates[0][1]));
$polygon_area = 0;
for ($i=0;$i <= $array_length;$i++){
$polygon_area += (
($polygon_coordinates[$i][0] *
$polygon_coordinates[$i+1][1])-
($polygon_coordinates[$i][1] *
$polygon_coordinates[$i+1][0]));
$polygon_area = abs($polygon_area / 2);
else {
$polygon_area = 'need at least 3 points';
return $polygon_area;
