Generating a map with mapfile context document
rock well
rockwell_001 at YAHOO.COM
Wed Jul 19 18:09:38 EDT 2006
Hi all, i am trying to generate a map from mapfile context document. I have a mapfile with a raster layer,
MAP
NAME "wallmap"
SIZE 600 600
STATUS ON
EXTENT 610537 5291088 627571 5308122
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
UNITS METERS
WEB
TEMPLATE "C:\Inetpub\wwwroot\index.html"
IMAGEPATH "c:\Inetpub\wwwroot\tmp\"
IMAGEURL "c:\Inetpub\wwwroot\tmp\"
END
LAYER
NAME "raster1"
TYPE RASTER
PROJECTION
"init=epsg:26914"
END
DATA "pathtotestfile.sid"
OFFSITE 0 0 0
STATUS OFF
END
END
The mapcontext document is as follows
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<ViewContext version="1.0.0" id="wallmap" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://www.opengis.net/context" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd">
<General>
<Window width="600" height="600"/>
<!-- Bounding box corners and spatial reference system -->
<BoundingBox SRS="EPSG:4269" minx="610537.000000" miny="5291088.000000" maxx="627571.000000" maxy="5308122.000000"/>
<!-- Title of Context -->
<Title>WMS Demo Server</Title>
</General>
<LayerList>
<Layer queryable="" hidden="0">
<Server service="WMS" version="1.1.1" title="raster1">
<OnlineResource xlink:type="simple" xlink:href="http://localhost/scripts/mapserv.exe?"/>
</Server>
<Name>raster1</Name>
<Title>raster1</Title>
<Abstract>Info</Abstract>
<SRS>EPSG:26914 </SRS>
<FormatList>
<Format>image/jpeg</Format>
</FormatList>
<StyleList>
<Style current="1">
<Name>0xb8d8f6</Name>
<Title>0xb8d8f6</Title>
<LegendURL width="16" height="16" format="image/jpeg">
<OnlineResource xlink:type="simple" xlink:href=""/>
</LegendURL>
</Style>
</StyleList>
</Layer>
</LayerList>
</ViewContext>
when i inlcude this context file in the browser, nothing gets displayed, the url is as follows
http://localhost/scripts/mapserv.exe?MODE=map&MAP=c:/Inetpub/wwwroot/testmap.map&CONTEXT=c:/Inetpub/wwwroot/contextdoc.xml&LAYERS=raster1
What more do i need to add, do i need to add anything else in the url, if anyone has generated a map with context file can you suggest whats missing ...
Thanks for your time ...
kris
See the all-new, redesigned Yahoo.com. Check it out.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060719/f66a8f23/attachment.html
