MapServer Java?
Norman Barker
nbarker at ITTVIS.COM
Thu Jul 20 03:52:58 EDT 2006
There have been a few replies to this thread, but if you use a servlet
then I find using the init method quite helpful
public void init() throws ServletException {
super.init();
ServletConfig config = getServletConfig();
mapfile = config.getInitParameter("mapfile");
And in web.xml
<init-param>
<param-name>mapfile</param-name>
<param-value>/var/www/html/demo/bluemarble.map</param-value>
</init-param>
Just allows you to change the mapfile whenever you want and not have to
recompile.
Norman
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Umberto Nicoletti
Sent: Thursday, July 20, 2006 7:43 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] MapServer Java?
You could also use a jsp (which in fact is a special type of servlet).
The tutorial from Sun's java site will help you to get started with
both of them (and much more):
http://java.sun.com/j2ee/1.4/docs/tutorial/doc/
Good luck,
Umberto
On 7/20/06, Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote:
> I was able to create a java program which uses java mapscript, but now
how do i
> get that program to run on my server so clients can access it. It
seems like a
> java Servlet is the way to go but i cant find any good tutorials on
how to get
> started. I know what the code looks like for a servelt (example
below) but
> once i have that written where do i put it? do i need to install
anything else
> to get it to run? I am running Apache on fedora core 5.
> Servelt code:
> import java.io.*;
> import javax.servlet.http.*;
> import javax.servlet.*;
> public class Servlet_test extends HttpServlet {
> public void doGet (HttpServletRequest req,HttpServletResponse res)
> throws ServletException, IOException
> PrintWriter out = res.getWriter();
> out.println("Hello, world!");
> out.close();
