Please help me with buffer in JavaMapscript!!!!
Alejandro Rico
jarg58 at GMAIL.COM
Fri Jul 21 16:28:34 EDT 2006
Hi !!!
try to put in your /etc/ld.so.conf the line /usr/local/lib
and then run ldconfig, this let mapserver find the libraries needed to
execute properly.
On 7/21/06, Reyes, Mariano <mreyes at siscat.com.ar> wrote:
> Hi,
> I have a problem with shapeObj.buffer( int i ), when call buffer I get
> this error:
> Exception in thread "main" java.lang.UnknownError: GEOS support is not
> available
> My code is:
> pointObj punto = new pointObj( 250, 250, 0 );
> lineObj line = new lineObj();
> line.add(punto);
> shapeObj shape = new shapeObj( mapscriptConstants.MS_SHP_ARCM );
> shape.add( line );
> shapeObj buff = shape.buffer( 200 );
> Then I try compiler mapserver with geos, and in make test of
> mapscript/java I have this message of error:
> # An unexpected error has been detected by HotSpot Virtual Machine:
> # SIGSEGV (0xb) at pc=0x400a89b0, pid=30009, tid=1075228800
> # Java VM: Java HotSpot (TM) Client VM ( 1.4.2_11-b06 mixed mode )
> # Problematic frame:
> # C [libc.so.6+0x729b0]
> Please help me!!!!
> Thank You!!!!
> Mariano Reyes
> Buenos Aires, Argentina
Alejandro Rico
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060721/f78e9cd4/attachment.html
