mapserver as wms client - gracefully handling errors
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Mon Jul 24 15:42:13 EDT 2006
Hi Matthew,
I haven't tested, but the following could work (it should according to
the WMS spec :-) ):
"wms_exceptions_format "*application/vnd.ogc.se_blank *"
Best regards,
Bart
Matthew Perry wrote:
> Hey folks,
> I've set up a mapfile with a number of datasets plus the terraserver
> wms. When browsing parts of the earth not covered by terraserver,
> however, an in-image error message appears:
> msDrawMap(): WMS connection error. Failed to draw WMS layer named
> 'Terraserver_DOQ'. This most likely happened because the
> remote WMS server returned an invalid image, and XML exception or
> another unexpected result in response to the GetMap request. Also
> check and make sure that the layer's connection URL is valid.
> I can get the wms client and my wms server to return xml instead of an
> inline error but the real question is, how do I force mapserver to
> simply ignore the cascaded wms when an error occurs so that it can
> still render the other data in the mapfile without returning an
> exception?
> Here's my mapfile entry for reference:
> LAYER
> NAME "Terraserver_DOQ"
> STATUS OFF
> TYPE RASTER
> GROUP "main"
> CONNECTIONTYPE WMS
> CONNECTION "http://terraservice.net/OgcMap.ashx?"
> DEBUG ON
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_title" "Digital_Orthophoto"
> "wms_name" "DOQ"
> "wms_server_version" "1.1.1"
> "wms_exceptions_format" "application/vnd.ogc.se_xml"
> "wms_format" "image/jpeg"
> "wms_layers" "doq"
> END
> MINSCALE 10000
> MAXSCALE 40000
> PROJECTION
> "init=epsg:4326"
> END
> END
OSGIS, Open Source GIS
http://www.osgis.nl
