UDig & Mapserver WFS
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed Jul 26 15:01:28 EDT 2006
Later on I realized this means Mapserver's parameter checking is more
strict (therefore correct) on DescribeFeatureType than on GetFeature.
Since parameter values need to be interpreted case-sensitive, it should
already report on your GetFeature request with capitals instead of
Capitals that it does not know of such a typename. Instead of that it's
using the value of the typename parameter in the DescribeFeatureType url
and giving back there an error that it does not know of such a feature
type later on.
I have opened up a bug for this:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1848
Best regards,
Bart
Bart van den Eijnden (OSGIS) wrote:
> I think your problem is with the schema (DescribeFeatureType
> refererence in the GML response).
> If I use:
> http://ogc.midwestsurveys.com/geoserve/ms?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=capitals&OUTPUTFORMAT=XMLSCHEMA
> I don't get back the schema.
> capitals should be Capitals then it works.
> uDIG is very sensitive to such things.
> Best regards,
> Bart
> Angus Dickey wrote:
>> Hey List,
>> Has anybody tried using UDig as a client for a WFS service from
>> Mapserver? I have mapserver running a WFS service that seems to
>> produce fine GML, some other clients can connect correctly, but UDig
>> always errors out.
>> I will post the actual error to the UDig list, but was hoping
>> somebody might have some insight into whether this is a UDig or
>> Mapserver problem.
>> For a sample mapserver response try this:
>> http://ogc.midwestsurveys.com/geoserve/ms?SERVICE=WFS&version=1.0.0&request=getfeature&TYPENAME=capitals&OUTPUTFORMAT=gml2
>> Thanks,
>> ~Angus
OSGIS, Open Source GIS
http://www.osgis.nl
