Problem with MAXSCALE and STATUS on wms layer
Little, John
JLittle at NRCAN.GC.CA
Thu Jul 27 13:54:27 EDT 2006
Hi all,
I'm having a problem using MAXSCALE and STATUS on a layer that I'm
accessing through wms.
Here's the situation: I have two road layers, "Roads" which I have
locally and "NTS_Roads" which I connect to through wms. I have the
MINSCALE for "Roads" set at 500000, and the MAXSCALE for "NTS_Roads" set
to 500000. Both STATUS for both layers should be ON.
The "Roads" layer does disappear when the appropriate scale is reached,
AND the "NTS_Roads" layers does show up on the legend when zoomed into
the set scale, BUT the "NTS_Roads" are not turned on. (The layer DOES
display properly when turned on).
Am I missing something in my mapfile - or is there some problem related
to wms connection?
I had experienced similar problems before with some of my local data,
but I got around the problem by using an SLD to render the layer and set
the min and maxscaledenominator tags, however I don't believe I can use
an SLD on a wms layer (I've tried and it didn't work - am I correct?).
Here's the "NTS_Roads" layer from my mapfile
#### NTS TEST ROADS ####
LAYER
TEMPLATE "dummy.html"
NAME "NTS_Roads"
GROUP "Base Layers"
MAXSCALE 500000
CONNECTIONTYPE WMS
CONNECTION "https://ca.nfis.org/cubewerx/cubeserv/cubeserv.cgi?...."
UNITS METERS
METADATA
"wms_title" "NTS Roads (250K)"
"wms_abstract" ""
"legend_type" "layer"
"wms_sld_body" "AUTO"
END
PROJECTION
"init=epsg:42304"
END
STATUS default
TYPE LINE
END
Please let me know if you know of a fix. Thanks!
John
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060727/2be7c5a3/attachment.html
