3D Polygon
Joe Bussell
joe at OTSYS.COM
Thu Jul 27 16:18:19 EDT 2006
What does
shpinfo.pl -file=[your 3D filename]
produce?
Joe Bussell
On Time Systems
K S wrote:
> Sorry for the delay! Thanks for the response!
> Here is the report of ogrinfo for the shapefile. Supposed that the
> precompiled version of mapserver doesn't support 3D polygon how can I
> "enable" 3D polygons' support?
> Layer name: TownBlocks
> Geometry: 3D Polygon
> Feature Count: 8024
> Extent: (496798.420507, 3874382.779711) - (692235.890369, 3932301.842024)
> Layer SRS WKT:
> PROJCS["Greek_Grid",
> GEOGCS["GCS_GGRS_1987",
> DATUM["Greek_Geodetic_Reference_System_1987",
> SPHEROID["GRS_1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["False_Easting",500000.0],
> PARAMETER["False_Northing",0.0],
> PARAMETER["Central_Meridian",24.0],
> PARAMETER["Scale_Factor",0.9996],
> PARAMETER["Latitude_Of_Origin",0.0],
> UNIT["Meter",1.0]]
> OBJECTID: Integer (9.0)
> FID_?ώΆΎϊΎ: Integer (9.0)
> SDE_blockc: Real (19.11)
> PERIMETER: Real (19.11)
> TBLOCK_: Real (19.11)
> TBLOCK_ID: Real (19.11)
> ESYE_CODE: Integer (9.0)
> MATCH_: Integer (9.0)
> XBLOCK: Real (19.11)
> YBLOCK: Real (19.11)
> MUN_NAME: String (40.0)
> MUN_CODE: String (8.0)
> OT: String (12.0)
> TR_POP: Real (19.11)
> PER_POP: Real (19.11)
> NOIK: Real (19.11)
> HOUSES: Real (19.11)
> H_OWN: Real (19.11)
> H_REN: Real (19.11)
> H_KAT: Real (19.11)
> H_KEN: Real (19.11)
> H_KY_KA: Real (19.11)
> H_EXOH: Real (19.11)
> PER_MEN: Real (19.11)
> PER_WOM: Real (19.11)
> AGE14: Real (19.11)
> AGE1564: Real (19.11)
> AGE65: Real (19.11)
> YDR: Real (19.11)
> EDR: Real (19.11)
> H_PKEN: Real (19.11)
> H_PREN: Real (19.11)
> H_POWN: Real (19.11)
> H_PEXOH: Real (19.11)
> M_W_RAT: Real (19.11)
> NOIK_MESO: Real (19.11)
> POPDEN: Real (19.11)
> FID_LLNew_: Integer (9.0)
> Shape_Leng: Real (19.11)
> Shape_Ar_1: Real (19.11)
> Shape_Le_1: Real (19.11)
> Shape_Area: Real (19.11)
> */"Bart van den Eijnden (OSGIS)" <bartvde at XS4ALL.NL>/* έγραψε:
> What does ogrinfo report on your shapefile? Can you send us the
> output?
> Best regards,
> Bart
> > I have tried using TYPE POLYGON in this LAYER but mapserver
> keeps showing
> > the error message:
> > msDrawShapes() General error message. Only polygon shapes can be
> drawn
> > using a POLYGON layer definition.
> > I am using mapserver version 4.8.4 from the precompiled pack that is
> > distributed from maptools.org. I can use TYPE LINE for the LAYER
> > without getting any error but that doesn't result to the map I
> want to
> > show.Any ideas?
> > Thank you for the response!
> > "Bart van den Eijnden (OSGIS)" έγραψε: You should
> > just use TYPE POLYGON. Note I think you need Mapserver 4.6 or
> > greater, best to try with the latest release (4.8.X).
> > Btw, Mapserver has a compile option determining whether or not
> it will
> > pick up Z and M values.
> > # If you want to use shape Z and M parameter this option must be
> set.
> > # It's OFF by default.
> > #USE_POINT_Z_M=-DUSE_POINT_Z_M
> > USE_POINT_Z_M=
> > Best regards,
> > Bart
> > K S wrote:
> >> Hello everybody,
> >> I have a shapefile which is GEOMETRY: 3D POLYGON. How can i draw
> >> the layer for this shapefile. To be more specific what would be the
> >> TYPE of such a layer
> >> Thank you in advance
> >> Χρησιμοποιείτε Yahoo!
> >> Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail
> διαθέτει την
> >> καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
> >> http://login.yahoo.com/config/mail?.intl=gr
> > OSGIS, Open Source GIS
> > http://www.osgis.nl
> διαθέτει την
> Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την
