NetCDF WCS python script
Norman Barker
nbarker at ITTVIS.COM
Fri Jul 28 14:35:25 EDT 2006
this isn't really suitable to go on the WCS how to (which uses Steve Lime's perl script as an example), but I have pasted a below a python script that creates mapserver time index files var1index.shp, var2index.shp etc., for the netCDF driver in GDAL with subdatasets.
The script is crude (it was hacked quickly), hopefully someone will find it useful. The met community (as a result of GALEON) seem keen to host netCDF WCSs.
Norman
# Create index shapefile
# derived from example at http://zcologia.com/news/categorylist_html?cat_id=2 - Sean Gillies
import ogr
import os
import glob
import gdal
from time import strftime, strptime
for var in ['u','v']:
output = var + 'index.shp'
# Create the Shapefile
driver = ogr.GetDriverByName('ESRI Shapefile')
if os.path.exists(output):
driver.DeleteDataSource(output)
index_shp = driver.CreateDataSource(output)
index = index_shp.CreateLayer('quikscat',
geom_type=ogr.wkbPolygon)
fd = ogr.FieldDefn('LOCATION', ogr.OFTString)
fd.SetWidth(100)
index.CreateField(fd)
fdt = ogr.FieldDefn('TIME', ogr.OFTString)
fdt.SetWidth(30)
index.CreateField(fdt)
# Loop over a number of georeferenced images
# The data files are 4 deep
files = glob.glob('*/*/*/*.nc')
times = ""
for file in files:
# Get georeferencing and size of imagery
# read geoinfo from var component, missing geo-information at top level
subfilename = "NETCDF:" + "\"" + os.path.abspath(file) + "\"" + ":" + var;
dataset = gdal.Open(subfilename)
g = dataset.GetGeoTransform()
pixels = dataset.RasterXSize
lines = dataset.RasterYSize
minx = g[0]
maxx = minx + pixels * g[1]
maxy = g[3]
miny = maxy + lines * g[5]
# append to the 'index' layer
wkt = 'POLYGON ((%f %f, %f %f, %f %f, %f %f, %f %f))' \
% (minx, miny, minx, maxy, maxx, maxy, maxx, miny, minx, miny)
g = ogr.CreateGeometryFromWkt(wkt)
# calculate the date string, parse the ordinal date first
length = len(file)
dateStr = file[length - 12: length - 3]
date = strptime(dateStr, "%Y%j%H")
frmtDate = strftime("%Y-%m-%dT%H", date)
times += "," + frmtDate
f = ogr.Feature(feature_def=index.GetLayerDefn())
f.SetField(0, subfilename)
f.SetField(1, frmtDate)
f.SetGeometryDirectly(g)
index.CreateFeature(f)
f.Destroy()
# destroy index_shp to flush and close
index_shp.Destroy()
# print out times as they are useful for mapfile
print "TIMES VAR: " + var
print times[1:]
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060728/99e1a77c/attachment.html
