How do I create a new shapeObj from a list of shapeobj?
Frederico Lucca
fredlucca at GMAIL.COM
Tue May 2 14:24:24 EDT 2006
Bryon,
I have something in java...
public void addLine(double[] arg){
lineObj line = new lineObj();
for(int i=2;i<arg.length;i=i+2){
pointObj p = new pointObj(arg[i],arg[i+1],0);
line.add(p);
layerObj layer = map.getLayerByName("COSMETIC");
shapeObj shape = new shapeObj(mapscript.MS_SHAPE_LINE);
shape.add (line);
layer.addFeature(shape);
WHERE COSMETIC IS:
LAYER
NAME COSMETIC
TYPE LINE
STATUS DEFAULT
CLASS
STYLE
SIZE 5
SYMBOL 'street'
END
COLOR 255 0 0
OUTLINECOLOR 171 158 137
END
END
I use this to add a line to the map, temporarily.
[]'s
Fred
"Everything under the sun is in tune
But the sun is eclipsed by the moon"
On 4/27/06, Bryon Kenne <bryon at peoplegis.com> wrote:
> I am retrieving a list of shapes from a line shapefile file using the
> following code:
> for($x=0;$x<count($oShapeList);$x++)
> $oSelectedShape = $oRelationLayer->getshape(-1, $oShapeList[$x]);
> array_push($oShapeObjectList,$oSelectedShape);
> I want to merge this list of shapes into one shape (i.e. one line). I
> thought I could do it using the following code but it returns a "Fatal
> error: Object has an invalid _handle_ property":
> $oLine = ms_newShapeObj(MS_SHAPE_LINE);
> For($x=0; $x<count($oShapeObjectList);$x++)
> $oLine->add($oShapeObjectList[$x]);
> The goal here is to create one line, then use the GEOS - buffer(width)
> to create a polygon object that I can save to a new shapefile.
> Does anybody have any ideas? OR CODE!!!
> Sincerely,
> Bryon
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060502/702ae30e/attachment.html
