Problems showing mapInfo text layer without OGR
Andrew Williams
awilliams at RAPIDMAP.COM.AU
Tue May 2 19:08:15 EDT 2006
Fred,
I'm no master when it come to mapserver, but don't you need to define a font in the calss declaration? eg FONT Bitmap
SIZE 2
We've recently ported our Mapserver environment from Linux (worked perfectly) to a Windows environment.
We had and continue to have problems with fonts. We don't seem to be able to use true type fonts (I'm sure we'll sort it out). Hence my suggestion for Bitmap fonts.
regards
Andrew
-----Original Message-----
From: Frederico Lucca [mailto:fredlucca at GMAIL.COM]
Sent: Wed 5/3/2006 12:58 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Cc:
Subject: [UMN_MAPSERVER-USERS] Problems showing mapInfo text layer without OGR
Hello all,
I have a mapinfo text layer and i need to view it on the map.
I use ogr2ogr to convert to esri shape format and put in my mapfile but i can't see the layer.
I have a multi-thread environment, then i don't want to use OGR, because of mutex.
LAYER
NAME TB
TYPE annotation
#STYLEITEM "auto"
#CONNECTIONTYPE ogr
#CONNECTION "/var/www/maps/TB.TAB"
DATA "/var/www/maps/shp/TB"
STATUS DEFAULT
MINSCALE 1
MAXSCALE 50000
CLASS
COLOR 255 0 0
OUTLINECOLOR 171 158 137
END
END
Thanks in advance.
Fred
"Everything under the sun is in tune
But the sun is eclipsed by the moon"
