mapscript ShapeObj object with postgis layers with c#
Szekeres Tamás
szekeres.tamas at FREEMAIL.HU
Thu May 4 05:48:04 EDT 2006
Here is a sample code should work for the postgis layers as
well:
private void DumpResults(layerObj layer)
resultCacheMemberObj res;
shapeObj feature;
using (resultCacheObj results = layer.getResults())
if (results != null && results.numresults > 0)
// extracting the features found
layer.open();
for (int j=0; j < results.numresults; j++)
res = results.getResult(j);
feature = layer.getFeature(res.shapeindex, res.tileindex);
if (feature != null)
Trace.WriteLine(layer.name + " (" + feature.index + ")");
for (int i = 0; i < feature.numvalues; i++)
Trace.WriteLine(layer.getItem(i) + "=" +
feature.getValue(i));
layer.close();
public void QueryByShape(shapeObj shape)
if (shape != null)
Trace.WriteLine("The query shape is not specified.");
return;
try
if (shape.type == MS_SHAPE_TYPE.MS_SHAPE_POLYGON)
map.queryByShape(shape);
layerObj layer;
for (int i = 0; i < map.numlayers; i++)
layer = map.getLayer(i);
if (layer.status != mapscript.MS_OFF)
DumpResults(layer);
else
Trace.WriteLine("The query shape must be a polygon.");
catch (Exception e)
Trace.WriteLine("QueryByShape error: " + e.Message);
Best Regards,
Tamas
On Thu, 4 May 2006 09:48:51 +0200, Xavier Mauclaire
<xavier.mauclaire at GEOTER.FR> wrote:
>Hi
>I'm developping with VS 2003 for windows and mono with c#
plateform
>i may have a question cencerning the shapeobj object : Can
i use this object
>with objects coming from Postgis Layers ?
>If yes how can i get attributes values (all values are
empty ) ?
>May the function like querybyshape using data from postgis
be retunring
>wrong result (Numresults is wrong) . is there any problems
with postgis
>layer ?
>On the other hand i may be mistaken using this function :-)
>Any help will be appreciated
>regards
>Xavier Mauclaire
_______________________________________________________________________________
Anyák napja - ugye nem felejti el?
http://www.bookline.hu/control/shlist?id=60&affiliate=freanykar2482
