Plz Help in OGR and MYSQL
Frank Warmerdam
warmerdam at POBOX.COM
Thu May 4 09:04:31 EDT 2006
grabiel wrote:
> connectiontype ogr
> connection "n_state.shp"
> DATA "SELECT * from nsdata left join 'MYSQL:test,
> host=localhost, user=root'.nsdata ON n_state.st_nm=nsdata.name"
> END
> END
Grabriel,
I think you want:
SELECT * from n_state LEFT JOIN ...
The n_state player (from the shapefile) is the primary table.
You should be able to test the left join from ogrinfo as well using
the -sql command option.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
