error en http
Graham Davis
gdavis at REFRACTIONS.NET
Thu May 4 12:08:03 EDT 2006
Try
http://10.1.6.46/cgi-bin/mapserv?map=/home/earevalo/mapserver-4.8.3/tests/test.map&layer=Testing&mode=map
<http://10.1.6.46/cgi-bin/mapserv?map:/home/earevalo/mapserver-4.8.3/tests/test.map&layer=Testing&mode=map>
You need to use = and not :
Graham Davis
Refractions Research Inc.
gdavis at refractions.net
Eduardo Arévalo wrote:
> please help:
> error
> loadMap(): Web application error. CGI variable "map" is not set.
