[UMN_MAPSERVER-USERS] MapServer, IIS and Oracle
Léveillé, James
James.Leveille at MTQ.GOUV.QC.CA
Fri May 5 07:18:02 EDT 2006
Yes, I did reboot ...
The real problem was that I had to give READ permissions on the
"tnsnames.ora" and "Sqlnet.ora" files to the internet user.
Now, its work fine.
Thanks
James Léveillé
Intélec Géomatique
420, boul. Charest Est
Bureau 400
Québec (QC), Canada
G1K 8M4
Intélec Géomatique: 418.687.5000
MTQ: 418.380.2005 (#227)
-----Message d'origine-----
De : Bart van den Eijnden (OSGIS) [mailto:bartvde at xs4all.nl]
Envoyé : 5 mai 2006 03:40
À : Léveillé, James
Cc : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] MapServer, IIS and Oracle
IIS only picks up new system environment variables after a reboot. Did
you reboot?
Best regards,
Bart
Léveillé wrote:
> Hi,
> I've been using MapServer (with Apache) with Oracle (10g) on Win XP.
> Everything use to work perfectly ...
> I'm now trying to make MapServer work on IIS, instead of Apache. I'm
> using the same computer, but Apache was removed. Here is what I did:
> - MS4W was downloaded and unzipped.
> - libmap.dll was downloaded and the original one was replaced (in
> ...\ms4w\Apache\cgi-bin).
> - 3 Env. vars were defined, as specified in (
> http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto/view
> <http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto/view>).
> - Full control was given (for now) to the internet user on the Oracle
> home directory.
> - getCapabilities looks OK (INPUT=ORACLESPATIAL)
> As I recall, I'm using the same computer, so the Oracle connection
> should be fine (it was working fine).
> But I get the following error when testing :
> *The WMS Server issued the following exception: msDrawMap(): Image
> handling error. Failed to draw layer named 'MyLayer'.
> msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI
> Handlers. Connection failure. Check the connection string. Error:
> ORA-12154: TNS: could not resolve service name.*
> Any solutions ??
> Thanks
> *James Léveillé*
> *Intélec Géomatique*
> Bureau 400
> Québec (QC), Canada
> G1K 8M4
OSGIS, Open Source GIS
http://www.osgis.nl
