WMS client/cascading wms bounding box problem
Robert William Jones
xbobwjones at HOTMAIL.COM
Mon May 8 05:19:29 EDT 2006
I am trying to use MapServer as a WMS client to another WMS (cascading WMS).
The request I make is of the form:
http://localhost/cgi-bin/mapserv_44.exe?map=midas.map&version=1.1.1&request=getmap&layers=gs_lay&width=500&height=250&srs=epsg:4326&bbox=0,45,40,65&format=image/png
However, MapServer seems to do something strange to the bounding box as the
box that is submitted by MapServer (as part of the getmap request) is the
following:
0.039999999999997732,45.019999999999996,39.960000000000001,64.980000000000004
My map file is set up as follows:
MAP
STATUS ON
SIZE 500 250
EXTENT 0 45 40 65
SHAPEPATH "./data"
IMAGECOLOR 0 0 255
PROJECTION
"init=EPSG:4326"
END
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
LAYER
NAME "gs_lay"
TYPE RASTER
STATUS ON
CONNECTION "http://localhost:8080/geoserver/wms?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "topp:gfs"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_latlonboundingbox" "0 45 40 65"
END
END
END
Does anyone know why the bounding box is being changed, instead of being
submitted as is?
Many thanks for any help
Robert Jones
Software Engineer
ComSine Limited
Telephone: + 44 (0) 1483 457121
Fax: + 44 (0) 1483 304836
Mobile: +44 (0) 7939 295868
www.comsine.com
*Please Note:*
This text is confidential. If you are not the named addressee, it could
be unlawful for you to read, copy, distribute, disclose or use the
information contained herewith. If you are not the intended recipient
please telephone +44 (0) 1483 457121.
