[MapServer Error]: msQueryByPoint(): No matching record(s)
found. /OGR/MYSQL
Frank Warmerdam
warmerdam at POBOX.COM
Mon May 8 09:26:09 EDT 2006
grabiel wrote:
> Hi
> I have posted one message for ogr/mysql problem(No reply so far). If anyone has implemented ogr/mysql/php Plz. help me out. What i am trying is to relate a shape file with mysql table. I can able to fetch the data through ogrinfo in command line which is like this--->
> [root at localhost bin]ogrinfo /usr/local/apache/htdocs/gmap/htdocs/data/n_state.shp -sql "SELECT st_nm, nsdata.name,nsdata.capital,nsdata.id from n_state
> LEFT JOIN 'MYSQL:test,host=localhost,user=root,tables=nsdata'.nsdata ON n_state.st_nm=nsdata.name"
> The command above woks fine but when i try the same from mapfile, I am getting the following error.
>> Warning: [MapServer Error]: msQueryByPoint(): No matching record(s) found.
>> in /usr/local/apache/htdocs/gmap/htdocs/gmap75.inc.php on line 425
> The error above is only for the layer where i have used OGR/MySql table, whereas for layers where i havenot used OGR/MySql(simply shape file & Metadata) its showing the results.
> My mapfile code for ogr is something like this-->
> LAYER
> NAME "n_state"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "/usr/local/apache/htdocs/gmap/htdocs/data/n_state.shp"
> DATA "SELECT * from n_state left join 'MYSQL:test,host=localhost,user=root,tables=nsdata'.nsdata ON n_state.st_nm=nsdata.name"
> STATUS ON
> CLASSITEM "st_nm"
> CLASS
> NAME "NEIGHBOURING STATE"
> EXPRESSION /A*/
> COLOR 255 0 0
> OUTLINECOLOR 255 0 0
> SYMBOL "NS"
> END
> END
Grabriel,
Have you verified with ogrinfo that the attribute st_nm appears with the
expected values?
Try:
ogrinfo -ro /usr/local/apache/htdocs/gmap/htdocs/data/n_state.shp \
-sql "SELECT * from n_state left join
If everything looks ok there, then you might review your use of EXPRESSION.
It looks ok to me, but I'm not sure.
Good luck,
and watch the world go round - Rush | President OSGF, http://osgeo.org
