WMS Server call in .net
Piero Cavalieri
piero.cavalieri at GMAIL.COM
Tue May 9 03:58:58 EDT 2006
rock well ha scritto:
Hi all i was wondering if there is an equivalent script for wms request for
asp script with iis in the below link
http://ms.gis.umn.edu/docs/howto/wms_server,
i am trying to do the same thing in vb.net ....
Any suggestions please .....
I do:
public Map getMap(string queryString)
string mapImgUrl = null;
string mapwidth = null;
string mapheight = null;
string scalebar = null;
string imgxy = null; //[center] of the image
string imgext = null;
string legend = null;
string referenceMap = null;
Map map = null; //holds all map value
try {
HttpWebRequest webRequest = (HttpWebRequest)
WebRequest.Create(queryString);
webRequest.Timeout=10000;
webRequest.Method = "GET";
// Send the WebRequest and read response
HttpWebResponse webResponse = (HttpWebResponse)
webRequest.GetResponse();
Stream sResponse = webResponse.GetResponseStream();
StreamReader reader = new StreamReader(sResponse);
//first line is additional info from MapServer
string header = reader.ReadLine();
if(header == "<HTML>") { //error
string message = reader.ReadToEnd();
message += "\n\n\"" + header + message + "\"\n\n";
throw new Exception(message);
//actual parameters
XmlDocument xmldoc = new XmlDocument();
string doc = reader.ReadToEnd();
xmldoc.LoadXml(doc);
xmldoc.PreserveWhitespace = true;
XmlNode root = xmldoc.DocumentElement;
mapImgUrl = root.SelectSingleNode
("img").Attributes["value"].Value;
mapwidth = root.SelectSingleNode
("mapwidth").Attributes["value"].Value;
mapheight = root.SelectSingleNode
("mapheight").Attributes["value"].Value;
scalebar = root.SelectSingleNode
("scalebar").Attributes["value"].Value;
imgxy = root.SelectSingleNode
("imgxy").Attributes["value"].Value;
imgext = root.SelectSingleNode
("imgext").Attributes["value"].Value;
referenceMap = root.SelectSingleNode
("referenceMap").Attributes["value"].Value;
legend = root.SelectSingleNode("legend").InnerText;
sResponse.Close();
reader.Close();
webResponse.Close();
map = new Map(mapImgUrl, mapwidth, mapheight, scalebar,
imgxy, imgext, legend, referenceMap);
sResponse.Close();
reader.Close();
} catch (Exception ex) {
throw new
Exception("queryString:"+queryString+"\n"+ex.StackTrace);
return map;
} //method
web_template.xml:
<?xml version="1.0" encoding="utf-8" ?>
<map>
<img value="[img]"/>
<mapwidth value="[mapwidth]"/>
<mapheight value="[mapheight]"/>
<scalebar value="[scalebar]"/>
<referenceMap value="[ref]"/>
<imgxy value="[center]"/>
<imgext value="[mapext]"/>
<legend>
<![CDATA[
[legend]
</legend>
</map>
[Serializable]
public class Map
public string mapImgUrl = "";
public string mapwidth = "";
public string mapheight = "";
public string scalebar = "";
public string imgxy = "";
public string imgext = "";
public string legend = "";
public string referenceMap = "";
public Map(string mapImgUrl, string mapwidth, string mapheight,
string scalebar, string imgxy, string imgext, string legend, string
referenceMap)
this.mapImgUrl = mapImgUrl;
this.mapwidth = mapwidth;
this.mapheight = mapheight;
this.scalebar = scalebar;
this.imgxy = imgxy;
this.imgext = imgext;
this.legend = legend;
this.referenceMap = referenceMap;
How u do the call depends if u use postbacks or ajax. If ajax, wrap the
method with ajax serverside call, and then do javascript call to that
method (this depends on ajax library used, I used AjaxPro).
If postbacks, u do the work in PageLoad. Take posted parameters from user
interface, build the url, call the method above (or similar...), then u can
use returned values (image url, extension ecc.) in the Page with classic asp
style: <image src="<%= mapUrl%>" /> ecc.
Ciao
Piero
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060509/27b2cb76/attachment.html
