generated SVG-File
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue May 9 10:24:33 EDT 2006
Andreas Nemmert wrote:
> Hy,
> I set up my Mapfile so that my MapServer generates SVG-Files.
> Is it possible that the MapServer generates groups in this SVG File?
Are you refering to the possibility to have the <g> tag around all
layers that share the same group name in the map file ? It should be
possible although groups in mapserver do not affect the order in which
layers are displayed. I am under the impression that if we do that for
the svg output, we would need to affect the rendering order. I have
entered a bug on this, so please update the bug with you comments and
possible solutions. (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1774)
> When I send a GetMap Request all the layers I requested are in the SCG
> File, but I can not handle one single layer. Do I have to request every
> layer individual?
Not sure to understand : are you using mapserver cgi and doing a
mode=map ? In that case you are able to specficy an individual layer
using the parameter layers
(http://127.0.0.1/cgi-bin/mapserv.exe?map=c:/example.map&mode=map&layers=layers1)
Make sure that the ststus of your layers in the map file are not set
to DEFAULT. All layers with the DEFAULT status will be rendered all the
time.
> Is there any chance to revise the colours of features in the requested
> SVG file?
Not sure to undertand this.
> Thank you for your help!
> Andreas Nemmert
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
