Tiling for mapserver.
Stephen Gornick
sgornick at DIGICOAST.COM
Tue May 9 13:56:54 EDT 2006
If you are referring to tiles to be layered over existing Google tiles,
see Ducky Sherwood's census mashup site:
http://maps.webfoot.com/
She did that as a project for one of her courses:
http://www.cs.ubc.ca/~tmm/courses/infovis/projects.html#ducky
Specifically, she writes:
"I used the gd library[3] to draw the polygons (as given in the
shapefiles), filled with a color chosen based on the population (as
given population datafiles) divided by the area (as given in the shape
file). I wrote files out as PNG images."
I was trying to figure out how to get the output from shp2img to create
tile layers, but now am looking at using gd as well.
- Regards,
- Stephen
Edlinoor Syahril Ramlan wrote:
> Hi guys,
> I don't know whether this is a stupid question or what but I really
> need some advice, opinions, or whatever since I am stuck with this
> problem for so many days already.
> Anyway what I am trying to do is to create map images that I can use
> to implement my application like Google Maps. I know that within
> Mapserver there is ka-map but as stupid as I am, I would like to
> create my own. The details of ka-map and the lack of documentation
> making ka-map a bit confusing to me.
> I need to make tiles for all map images that I generated from .map
> file. The problem I have is that I don't know how to generate images
> for zooming in and out the map. I've tried changing and using EXTEND
> variable but EXTEND only displayed a certain area of the map and not
> the entire data. So basically if the user drag the map they will only
> see data on that extend and not the entire map. How can I solve this
> problem? I tried using and changing the SCALE value but nothing
> changed? I tried to changed the SIZE also nothing changed except the
> pixel size of the map.
> So anybody out there that can help me with the best approach? I need
> to generate the image and then cut it to tiles. I think I have a
> solution on how to cut the image but producing the image is now the
> problem. I hope you guys get the picture.
> Thanks.
> Ed.
