WFS geometry attribute
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Tue May 9 09:30:43 EDT 2006
Yes you can, use the following METADATA for your LAYER:
"gml_geometries" "thenameyouwant"
"gml_thenameyouwant_type" "multipolygon"
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Daniel Vencler
Verzonden: dinsdag 9 mei 2006 15:23
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] WFS geometry attribute
I am trying to setup WFS with MapServer 4.8.3 but I need to change
geometry attribute name from msGeometry to gml:polygonProperty or which
ever geometry type current feature uses. I need this to be able to
validate MapServer generated GML with separately genrated schema.
So, can msGeometry be substituted with something little less
MapServer specific?
Best regards,
Daniel Vencler
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060509/371799c3/attachment.html
