Help needed in Raster/World file
grabiel
grabiel at MYWAY.COM
Wed May 10 02:43:44 EDT 2006
Hi
Ed
You are right. I didnot set any georeference information set
or project information in the .tif file. I simply took one image and trying to display it along with other layers. Also i need to integrate the image with other layer. Can you please tell me how to set the georeference/projection information in my .tif file.
Thanks in advance.
Raffle
--- On Tue 05/09, Ed McNierney < ed at TOPOZONE.COM > wrote:
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Tue, 9 May 2006 08:21:23 -0400
Subject: Re: [UMN_MAPSERVER-USERS] Help needed in Raster/World file
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=us-ascii">
<META content="MSHTML 6.00.2900.2873" name=GENERATOR></HEAD>
<BODY>
<DIV dir=ltr align=left><SPAN class=190061912-09052006><FONT face=Arial
color=#0000ff size=2>Raffle -</FONT></SPAN></DIV>
color=#0000ff size=2></FONT></SPAN> </DIV>
color=#0000ff size=2>That's an important difference! If you have a TFW
file in the first place, gdalinfo will simply return its contents to you.
So you're using the contents of your TFW file to decide what information to put
in your TFW file....</FONT></SPAN></DIV>
color=#0000ff size=2>You seem to have no georeferencing information in that
file. What information do you have about the projection and coordinate
extents of that input image? Do you need to only display this single
layer, or do you need to integrate it with other data
layers?</FONT></SPAN></DIV>
color=#0000ff size=2> - Ed</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=190061912-09052006><!-- Converted from text/plain format -->
<P><FONT size=2>Ed McNierney<BR>President and Chief Mapmaker<BR>TopoZone.com /
Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North Chelmsford,
MA 01863<BR>Phone: +1 (978) 251-4242<BR>Fax: +1 (978)
251-1396<BR>ed at topozone.com</FONT> </P></SPAN></DIV><BR>
<DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left>
<HR tabIndex=-1>
<FONT face=Tahoma size=2><B>From:</B> UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] <B>On Behalf Of </B>raffle
peter<BR><B>Sent:</B> Tuesday, May 09, 2006 3:32 AM<BR><B>To:</B>
MAPSERVER-USERS at LISTS.UMN.EDU<BR><B>Subject:</B> Re: [UMN_MAPSERVER-USERS] Help
needed in Raster/World file<BR></FONT><BR></DIV>
<DIV></DIV>
<DIV>Hi</DIV>
<DIV> Ed</DIV>
<DIV> I changed the status from On to
Default but still its not working. One thing i want to tell you that if i delete
the .tfw file the output of gdalinfo also changed which like this---></DIV>
<DIV> </DIV>
<DIV> #gdalinfo test.tif ### Without test.tfw file
######</DIV>
<DIV>Driver: Gtiff/GeoTiff</DIV>
<DIV>Size is 1042, 722</DIV>
<DIV>Co-ordinate System is `'</DIV>
<DIV>METADATA</DIV>
<DIV>----------</DIV>
<DIV>Upper Left (0.0, 0.0)</DIV>
<DIV>Lower left (0.0, 722.0)</DIV>
<DIV>Upper right (1042.0, 0.0)</DIV>
<DIV>center(521.0, 361.0)</DIV>
<DIV> </DIV>
<DIV>Band 1 Block=1024*64 TYPE=BYTE, ColorInterp=RED</DIV>
<DIV>..........................................................................=Green</DIV>
<DIV>......................................................................=BLUE</DIV>
<DIV> </DIV>
<DIV>Then what will be my values in my .tfw file? Now if i put the values in my
.tfw file then the output of my gdalinfo also changed according to the values
that i put there.</DIV>
<DIV> </DIV>
<DIV>Where is the problem? Whether i need to put Projection statement in my
mapfile?</DIV>
<DIV>Please help me </DIV>
<DIV>Thanks in advance</DIV>
<DIV>Raffle<BR><BR><B><I>Ed McNierney <ed at topozone.com></I></B>
wrote:</DIV>
<BLOCKQUOTE class=replbq
style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">
<DIV dir=ltr align=left><SPAN class=290361611-08052006><FONT face=Arial
color=#0000ff size=2>If you set your LAYER to STATUS ON it won't display - you
need to set it to STATUS DEFAULT.</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=290361611-08052006><!-- Converted from text/plain format -->
<DIV><FONT size=2>Ed McNierney<BR>President and Chief Mapmaker<BR>TopoZone.com
/ Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North Chelmsford,
251-1396<BR>ed at topozone.com</FONT> </DIV></SPAN></DIV><BR>
<HR tabIndex=-1>
peter<BR><B>Sent:</B> Monday, May 08, 2006 7:12 AM<BR><B>To:</B>
Help needed in Raster/World file<BR></FONT><BR></DIV>
<DIV></DIV>
<DIV dir=ltr align=left><SPAN class=049394813-06052006><FONT face=Arial
color=#0000ff size=2>Hi</FONT></SPAN></DIV>
color=#0000ff> I have given the mapfile below and after
modifying the value as you suggested in</FONT></SPAN></DIV>
color=#0000ff>your previous, I am not getting the raster image on my final
output.</FONT></SPAN></DIV>
color=#0000ff></FONT></SPAN> </DIV>
color=#0000ff>Thanks in advance</FONT></SPAN></DIV>
color=#0000ff>Raffle</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=049394813-06052006><FONT size=2>
<DIV> </DIV>
<DIV>NAME "Europe"</DIV>
<DIV>SIZE 200 200</DIV>
<DIV>STATUS ON</DIV>
<DIV>SYMBOLSET ....."</DIV>
<DIV>EXTENT 2700051.860 2462746.020 3582564.801 3012459.468</DIV>
<DIV>UNITS METERS</DIV>
<DIV>SHAPEPATH " "</DIV>
<DIV></DIV>
<DIV>WEB</DIV>
<DIV>IMAGEPATH ""</DIV>
<DIV>IMAGEURL ""</DIV>
<DIV>END</DIV>
<DIV>.......</DIV>
<DIV>LAYER</DIV>
<DIV>DATA "/usr/local/apache/htdocs/gmap/htdocs/data/europe.tif"</DIV>
<DIV>NAME "raster_back"</DIV>
<DIV>TYPE RASTER</DIV>
<DIV>STATUS ON </DIV>
<DIV>END</DIV>
<DIV></DIV>
<DIV>END</DIV></FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=049394813-06052006></SPAN><SPAN
class=049394813-06052006></SPAN><SPAN class=049394813-06052006></SPAN><SPAN
class=049394813-06052006><FONT face=Arial color=#0000ff
color=#0000ff size=2>Zero is a perfectly nice number! There's nothing
wrong with 0.0 in your world file, especially in the second and third
lines. For the vast majority of raster images you will find that the
fourth line is the same as the first line with the sign reversed, and the
second and third lines are 0.0. A world file will often look
like:</FONT></SPAN></DIV>
color=#0000ff size=2>100.0</FONT></SPAN></DIV>
color=#0000ff size=2>0.0</FONT></SPAN></DIV>
color=#0000ff size=2>-100.0</FONT></SPAN></DIV>
color=#0000ff size=2>12345.67</FONT></SPAN></DIV>
color=#0000ff size=2>987654.32</FONT></SPAN></DIV>
<FONT face=Arial color=#0000ff size=2>- Ed</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=049394813-06052006><!-- Converted from text/plain format -->
<HR tabIndex=-1>
peter<BR><B>Sent:</B> Saturday, May 06, 2006 9:07 AM<BR><B>To:</B>
MAPSERVER-USERS at LISTS.UMN.EDU<BR><B>Subject:</B> [UMN_MAPSERVER-USERS] Help
<DIV></DIV>
<DIV> </DIV>
<DIV> Hi</DIV>
<DIV> I am trying to include a .tif file for raster
background. For that i have to write a .tfw(world file) for the corresponding
.tif file. The information that i need to put in the world file are X, Y Pixel
size, rotational co-efficient and X, Y location of the center of the top left
pixel. I am trying to find these values by using gdalinfo-- but some values
are 0.0</DIV>
<DIV>in their corresponding field.</DIV>
<DIV> Can anyone plz help me, how to get/set these values for the
world file so that i can</DIV>
<DIV>keep my raster data georeferenced with other layers in my mapfile.</DIV>
<DIV> </DIV>
<DIV>Raffle</DIV>
<DIV> </DIV>
<DIV>
<HR SIZE=1>
<FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>24 FIFA World Cup
tickets to be won with Yahoo! Mail. <A
href="http://us.rd.yahoo.com/mail/uk/taglines/default/fifa_trueswitch/*http://eur.i1.yimg.com/java.europe.yahoo.com/uk/mail/fu/trueswitch/index.html">Learn
more</A> </FONT></DIV></BLOCKQUOTE><BR>
<P>
<HR SIZE=1>
<FONT face=Arial size=2><A
href="http://us.rd.yahoo.com/mail/uk/taglines/default/photos/*http://uk.photos.yahoo.com/"><B>Yahoo!
Photos</B></A> <FONT color=red>NEW</FONT>, now offering a <A
href="http://us.rd.yahoo.com/mail/uk/taglines/default/photos/*http://uk.photos.yahoo.com/">quality
print service</A> from just 7p a photo.</FONT></BODY></HTML>
<p>
No banners. No pop-ups. No kidding.
Make My Way your home on the Web - http://www.myway.com
