enable logfile on IIS [2]
Huub Fleuren
hfl at HOME.NL
Thu May 11 06:33:00 EDT 2006
Hi all,
The clue i missed was that the environment variable ms_errorfile shoul
be a System Variable and not a User Variable
So now i have a logfile. Thanks for the tips
see also some answers
Chip Taylor wrote:
> Make sure your directory is read-write enabled in IIS and the system.
Emil Wrote
> It works with the WEB LOG parameter you described ...
this is not true (alas, i agree firmly that is should!)
> Have you tried putting an empty file 'mapserver.log' in 'd:/temp' before
> starting your app?
yes, but this is not necessary
> Have you checked the Windows event log files?
yes but there is nothing much in it
> Is the disk 'd:' a 'real disk' disk and not a mapped one?
yes all normal
regards Huub
