mapfile of connection to postgis .........
Dirk Jesko
ml.dje at GEOCONTENT.DE
Fri May 12 02:19:27 EDT 2006
Eduardo,
it seems that there is no spatial extent specified in the mapfile and
mapserver can not guess it. I guess, that you need to add an EXTEND in
the MAP part, like
MAP
IMAGETYPE PNG
SIZE 400 300
IMAGECOLOR 255 255 255
EXTENT 3100000 5200000 4100000 6200000
See the mapserver docs, which says
"EXTENT [minx] [miny] [maxx] [maxy]
The spatial extent of the map to be created. In most cases you will
need to specify this, although mapserver can sometimes (expensively)
calculate one if it is not specified."
If your layer is not to large (not to many features), try the bounding
box of the data. You can get it with the following query:
SELECT box2d("the_geom")
FROM "departamentos_tp_perud2002";
Regards,
Dirk
Eduardo Arévalo wrote:
> Hi list
> I must mapserver v 4.8.3 and one bases postgres v 8 with postgis 1.0.6
> on Centos 4.3
> mapfile of connection is:
> MAP
> IMAGETYPE PNG
> SIZE 400 300
> LAYER
> NAME Peru_dep
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres dbname=sighco host=localhost
> password=123456 port=5432"
> DATA "the_geom from departamentos_tp_perud2002"
> STATUS ON
> TYPE POLYGON
> END
> #CLASS
> NAME "Departamentos del Perú"
> #STYLE
> # COLOR 232 232 232
> #OUTLINECOLOR 32 32 32
> END
> END
> END
> END
> in order to invoke it:
> http://10.1.6.46/cgi-bin/mapserv?map=/home/earevalo/mapserver-4.8.3/tests/conect.map&layer=Peru_dep&mode=map
> <http://10.1.6.46/cgi-bin/mapserv?map=/home/earevalo/mapserver-4.8.3/tests/conect.map&layer=Peru_dep&mode=map>
> the errors are:
> msDrawMap(): Image handling error. Unable to initialize image.
> msCalculateScale(): General error message. Invalid image extent,
> minx=-1.000000, miny=-1.000000, maxx=-1.000000, maxy=-1.000000.
> mapserv(): Web application error. No way to generate map extent.
> aid please
