Help needed in ImageMap
Pratap
dwija_dey at REDIFFMAIL.COM
Fri May 12 04:18:11 EDT 2006
Hi
I am trying to emulate imagemap with mapserver from the example given in http://mapserver.gis.umn.edu/docs/howto/imagemaps/?searchterm=imagemap
I am tring to display a field from my shapefile.dbf on mouseover tooltip using the functionality of the above URL. But neither i am getting any error nor tooltip/mouseover functionality.
My Mapfile for imagemap is:
LAYER
NAME "city"
TYPE POINT
STATUS ON
DATA "city"
CLASSITEM "name"
CLASS
NAME "CITY NAME"
EXPRESSION /A*/
COLOR 255 0 0
OUTLINECOLOR 255 0 0
END
TEMPLATE "bodytemplate.html"
HEADER "imapheader.html"
FOOTER "imapfooter.html"
END
The content of template file bodytemplate.html is.
<area shape="circle" coords="[shpxy precision=0 proj=image yf=",4" xf=","]" href="http://my.url/mypage.cfm?region=[name]" title="[name]" alt="[name]">
Q.1)What will be the exact value of href above?
The content of template file imapheader.html is.
<map id="mymap" name="mymap">
Q.2)What will be the value of id and name above?
</map>
I am also passing layer=city mode=nquery and searchmap=true from my .phtml file to mapserver
Q.3) I am not using separate imagemap mapfile. Whether it is needed? what will be its contents, where i should
place it ? and i am using Gmap's PHP/Mapscript engine.
Can anyone please tell me where is the problem? Also any info on this topic will highly appreciated.
Thanks in advance for any help.
With regards.
Pratap
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060512/95ad9cd0/attachment.html
