Class Expressions
DjwStone
D.Stone at ED.AC.UK
Fri May 12 09:52:29 EDT 2006
I'm having difficulty setting up an EXPRESSION statement for a PostGIS layer.
The field being tested is a numeric representation of a date in YYYYMMDD
format so that ranges can be easily compared.
When the expression is (say):
EXPRESSION ('[fieldname]' ge '15010101')
everything works fine; I get the correct number of hits. Similarly,
EXPRESSION ('[fieldname]' le '16001231')
works as it should.
However, when I have:
EXPRESSION ('[fieldname]' ge '15010101') and ('[fieldname]' le '16001231')
I get no hits although there should be some.
Has anyone else had similar problems?
Cheers,
Dave
View this message in context: http://www.nabble.com/Class-Expressions-t1607707.html#a4358498
Sent from the Mapserver - User forum at Nabble.com.
