dBox alpha
Brent Lund
Brent.Lund at STATE.MN.US
Fri May 12 16:07:09 EDT 2006
Steve,
1) Have you used the dbox toolkit in conjunction with things like
position: absolute and z-index:2 ...? When I added these to my
html/css, I found that firefox got messed up (mouseover etc did not
work), IE kind of works - (mouseover worked and able to zoom in, but box
not drawn when selecting zoom area). I know that dbox and dcontainer set
position to absolute, so there is a conflict between the scripts and my
stylesheet. I'm currently picking through the scripts to see what I
can figure out - any suggestions?
2) What happened to the cross-browsers.com stuff (just curious)?
Catch a big walleye,
Brent
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu] On
Behalf Of Steve Lime
Sent: Wednesday, May 10, 2006 3:05 PM
To: MAPSERVER-USERS at lists.umn.edu
Subject: [UMN_MAPSERVER-USERS] dBox alpha
Hi folks: We've taken the time to clean up and document the code behind
the Landview application that folks might be familiar with and have an
"alpha" release available. You can get at it at:
http://maps.dnr.state.mn.us/tools/dbox
The code itself is in good shape and much of it has been in production
use for years. The packaging, install instructions and such are brand
new so bear with us.
Anyway, the distribution comes with an example interface using the
Itasca data from one of the main demos. You can see it running on our
servers at:
http://maps.dnr.state.mn.us/tools/dbox/example/example.html
Hopefully someone will find this useful...
Steve
