Unable to get a transparent layer using shp2img -t
Frank Warmerdam
warmerdam at POBOX.COM
Fri May 12 17:09:51 EDT 2006
cropwithdawn wrote:
> Here is the command:
> shp2img -t -m wfs_only.map -o wfs_only.png -i PNG
> The wfs_only.map is using a simple shapefile.
> I get a PNG file but it's not transparent. What's up?
JAB,
I have confirmed the problem, and determined it is because
map->transparent is now applied in msPostMapParseOutputFormatSetup().
This is already done by the time shp2img processes the -t flag.
Since it doesn't work, I have removed the switch from shp2img. Instead
you can add the line:
TRANSPARENT ON
in your mapfile.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
