Variable substutition on CONNECTIONTYPE OGR CONNECTION
OGRVRTDatasource (odbc)
Frank Warmerdam
warmerdam at POBOX.COM
Sun May 14 21:47:58 EDT 2006
Huub Fleuren wrote:
> Hi List,
> Something changed, but what is it.
> I'm using somthing like the following, so a ODBC datasource for a
> OGRVRTLayer with variable substitution for the CONNECTION statement.
> This works for me since i first used it in mapserv version 4.2.
> I compiled gdal 1.3.2 as i normally do; with Xerces, 2.7 this time.
> ogrinfo works on a similar ovf file without variable substutution.
> If i get something in the log file (this is not always the case) on this
> layer it is:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'kpxy'.
> msOGRFileNextShape(): OGR error. SetAttributeFilter() not supported
> on ExecuteSQL() results.
Huub,
Sorry, this is my fault. I improved error propagation in OGR and now
this error gets bubbled up to MapServer and terminates rendering of OGR
layers. Please file a bug on the issue in the GDAL/OGR bugzilla. This
is the same that I was recently discussing Mark Adams, and occured first
in GDAL 1.3.2. The error propagation was a good idea, but I didn't
anticipate this particular problem with some OGR drivers and MapServer.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
