Anti Aliasing
Xiaoming Zhu
Xiaoming.Zhu at NRM.SE
Tue May 16 07:17:12 EDT 2006
What happened with this mapserver? It goes like a circle. Did anyone
else meet this before? Same problem pop out without any reason after you
fixed that.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Vincent Schut
Sent: den 16 maj 2006 12:49
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Anti Aliasing
Vincent Schut wrote:
> Zhonghai Wang wrote:
>> Hi Vincent,
>> have you got a nice map image with the ANTIALIAS TRUE ?
>> if so , can you give me a clue how to do that?
> Unfortunately not, that's why I'm asking these questions... I was
> experimenting with antialiasing, but kept getting segmentation faults
or
> premature end of script errors in my apache logs. But I did not put
the
> 'transparency alpha' in my map laysers, because most of my layers for
> which I wanted aa are currently semitransparent polygons...
> I'll experiment with the transparency alpha thing later and post to
the
> list if it worked.
> Vincent.
> PS please do not only post your questions directly to me (or whoever
> posted a message to the list) but also to the list again (reply to all
> usually works well), so others can learn from it and/or share their
> experience.
Oops sorry for the PS, I only saw later that you *did* post it to the
list. Never mind, no offense meant...
Vincent.
