Anti Aliasing
ramesh karra
karrarm at YAHOO.COM
Tue May 16 14:35:15 EDT 2006
Thanks steve!
I made the changes you suggested but I started getting
script errors. It looks like the errors are due to
'PNG24'. I am using Mapserver 4.6. Do I need to use
4.8 or later to successfully use PNG24?
Thanks
Krishna
--- Steve Lime <Steve.Lime at DNR.STATE.MN.US> wrote:
> You need a couple of other things:
> - a 24-bit output format (e.g. IMAGETYPE PNG24)
> - alpha blending turned on for the layer (e.g.
> TRANSPARENCY ALPHA)
> That should get it working...
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-259-5473
> >>> ramesh karra <karrarm at YAHOO.COM> 05/15/06 6:49
> PM >>>
> Hi,
> I have added 'ANTIALIAS TRUE' to all my STYLE
> objects
> but I do not see any difference in the map that's
> displayed. I was hoping to see smooth lines but
> there
> was no difference in the way lines(representing
> roads)
> are drawn with or without anti-aliasing. Is this the
> expected behavior? How can I get smooth lines?
> My layer is defined as follows:
> LAYER
> NAME roads
> DATA droad1
> STATUS OFF
> TYPE LINE
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> NAME "Roads"
> MAXSCALE 80000
> MINSCALE 20000
> STYLE
> ANTIALIAS TRUE
> COLOR 150 150 150
> WIDTH 3
> END
> STYLE
> ANTIALIAS TRUE
> COLOR 255 255 255
> WIDTH 1
> END
> END
> END
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam
> protection around
> http://mail.yahoo.com
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
