Anti Aliasing
ramesh karra
karrarm at YAHOO.COM
Tue May 16 18:07:14 EDT 2006
Thanks steve!
I have upgraded to 4.8.3 and the roads/lines are
smooth... Looks really good.
Thanks
Ramesh
--- Steve Lime <Steve.Lime at DNR.STATE.MN.US> wrote:
> You need 4.8 or later to use antialiasing... ;-)
> >>> ramesh karra <karrarm at yahoo.com> 5/16/2006
> 1:35:15 PM >>>
> Thanks steve!
> I made the changes you suggested but I started
> getting
> script errors. It looks like the errors are due to
> 'PNG24'. I am using Mapserver 4.6. Do I need to use
> 4.8 or later to successfully use PNG24?
> Thanks
> Krishna
> > You need a couple of other things:
> > - a 24-bit output format (e.g. IMAGETYPE PNG24)
> > - alpha blending turned on for the layer (e.g.
> > TRANSPARENCY ALPHA)
> > That should get it working...
> > Steve
> > Stephen Lime
> > Data & Applications Manager
> > Minnesota DNR
> > 500 Lafayette Road
> > St. Paul, MN 55155
> > 651-259-5473
> > >>> ramesh karra <karrarm at YAHOO.COM> 05/15/06 6:49
> > PM >>>
> > Hi,
> > I have added 'ANTIALIAS TRUE' to all my STYLE
> > objects
> > but I do not see any difference in the map that's
> > displayed. I was hoping to see smooth lines but
> > there
> > was no difference in the way lines(representing
> > roads)
> > are drawn with or without anti-aliasing. Is this
> the
> > expected behavior? How can I get smooth lines?
> > My layer is defined as follows:
> > LAYER
> > NAME roads
> > DATA droad1
> > STATUS OFF
> > TYPE LINE
> > PROJECTION
> > "init=epsg:4326"
> > END
> > CLASS
> > NAME "Roads"
> > MAXSCALE 80000
> > MINSCALE 20000
> > STYLE
> > ANTIALIAS TRUE
> > COLOR 150 150 150
> > WIDTH 3
> > END
> > STYLE
> > ANTIALIAS TRUE
> > COLOR 255 255 255
> > WIDTH 1
> > END
> > END
> > END
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam? Yahoo! Mail has the best spam
> > protection around
> > http://mail.yahoo.com
> Do You Yahoo!?
> protection around
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
