Anti Aliasing
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Tue May 16 08:50:57 EDT 2006
Hi Perry,
I don't think 2 will work, since transparency cannot be defined at the STYLE
level. See also:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1155
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Pericles S. Nacionales
Verzonden: dinsdag 16 mei 2006 14:53
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] Anti Aliasing
Two things you can try...
1. define two layers--one for polygon without outline color with
transparency set to whatever number, and the other layer defined as line
and with transparency set to alpha.
2. Create two styles within the layer--1 for the polygon fill with
transparency set to whatever value you want, 1 for the outlinecolor with
transparency alpha.
I haven't tried the second one so I don't know if it works. ;) Make
sure the line layer (or the outline style) is drawn on top. If you
don't want the lines, then I don't know the answer.
-Perry
Vincent Schut wrote:
> Steve Lime wrote:
>> You need a couple of other things:
>> - a 24-bit output format (e.g. IMAGETYPE PNG24)
>> - alpha blending turned on for the layer (e.g. TRANSPARENCY ALPHA)
>> That should get it working...
> To chime in:
> But what if I want to have antialiasing *and* semi-transparency? How
> would I define e.g. a opacity of 60 when I already have 'transparency
> alpha' in my layer?
> Vincent.
>> Steve
>> Stephen Lime
>> Data & Applications Manager
>> Minnesota DNR
>> 500 Lafayette Road
>> St. Paul, MN 55155
>> 651-259-5473
>>>>> ramesh karra <karrarm at YAHOO.COM> 05/15/06 6:49 PM >>>
>> Hi,
>> I have added 'ANTIALIAS TRUE' to all my STYLE objects
>> but I do not see any difference in the map that's
>> displayed. I was hoping to see smooth lines but there
>> was no difference in the way lines(representing roads)
>> are drawn with or without anti-aliasing. Is this the
>> expected behavior? How can I get smooth lines?
>> My layer is defined as follows:
>> LAYER
>> NAME roads
>> DATA droad1
>> STATUS OFF
>> TYPE LINE
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CLASS
>> NAME "Roads"
>> MAXSCALE 80000
>> MINSCALE 20000
>> STYLE
>> ANTIALIAS TRUE
>> COLOR 150 150 150
>> WIDTH 3
>> END
>> STYLE
>> ANTIALIAS TRUE
>> COLOR 255 255 255
>> WIDTH 1
>> END
>> END
>> END
>> __________________________________________________
>> Do You Yahoo!?
>> Tired of spam? Yahoo! Mail has the best spam protection around
>> http://mail.yahoo.com
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060516/4adee9d6/attachment.html
