React on query error
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Wed May 17 10:38:55 EDT 2006
>> Hi, my application offers the possibility to preselect countries
>> that should be displayed on the map. Thus, instead of having all
>> countries, I get only these preselected ones mapped; the others
>> are grayed out. But if a user now uses the query tool and clicks
>> on one of those not-preselected countries, than an mapscript
>> error occurs (naturally). Is there a way to react on such an
>> error warning and continue at another point, so that this
>> "problem" is just ignored and the application can continue to
>> work? if (!$imgbox)
>> $map -> queryByPoint($click_pt, MS_MULTIPLE, -1); // here is
>> then the error
>> else
>> $map -> queryByRect($click_rt); "Warning: [MapServer Error]:
>> msQueryByPoint(): No matching record(s) found. in /www/
>> geodataportal/htdocs/mod_map/etc/php/query.php on line 42" Thanks
>> for any help!
> Stefan,
> Being that is just a warning message you should be able to set a
> variable to the result of the queryByPoint and then test for
> MS_SUCCESS or MS_FAILURE and react accordingly.
> Lowell
Thanks for that. I did it now the following way:
//Query the Map at the point clicked
if (!$imgbox)
@ $a = $map -> queryByPoint($click_pt, MS_MULTIPLE, -1);
else
@ $a = $map -> queryByRect($click_rt);
if ($a == MS_SUCCESS)
xxxx
