OGR failing on Linux with Premature end of script headers
McGraw, Joanne
mcgrawj at AGR.GC.CA
Thu May 18 16:18:43 EDT 2006
I did. There's about six of them. I don't have access to the Apache config files.
Joanne T. McGraw
GIS Data Analyst / Analyste des données du SIG
Agriculture and Agri-Food Canada / Agriculture et Agroalimentaire Canada
Telephone/Téléphone: 613 759-6103
Facsimile/Télécopieur: 613 759-1937
960 Carling Ave, Bldg. 20, Rm. 1136
Ottawa, Ontario
K1A 0C6
mcgrawj at agr.gc.ca
www.agr.gc.ca/nlwis-snite
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Thursday, May 18, 2006 4:17 PM
To: McGraw, Joanne
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] OGR failing on Linux with Premature end of script headers
Try "locate libgdal" which should show you where all copies of files
with libgdal in the name are located on your system.
-Steve
McGraw, Joanne wrote:
> Hi Frank,
> Nice to hear from you! Hope all is well down your way. No gloating about the Senators loss.
> I tried your suggestion and didn't get any additional information:
> [mcgrawj at siswebdev temp]$/server/dev4.wms1/bin/shp2img -m /data/dev1.wms1.www/htdocs/gdas/temp/map1147200518.map -o junk.png
> Segmentation fault
> I'm trying to track down which version of libgdal.so we're actually pointing to, but will have to wait to talk to the configuration manager for that machine. I feel it is entirely possible (likely?) that old versions of the libraries are being used.
> Thanks for the suggestion.
> jtm
> Joanne T. McGraw
> Ottawa, Ontario
> K1A 0C6
> From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam
> Sent: Thursday, May 18, 2006 3:44 PM
> To: McGraw, Joanne
>>LAYER NAME "ecozones" DATA "ecozones"
>># CONNECTION "/ms4w_1.4.0/Apache/htdocs/dev1/data/ecozones.shp" #
>>CONNECTIONTYPE OGR # DATA "SELECT * FROM ecozones"
>>: END
>>In the browser, when I enter the following URL with the above definition,
>>the image appears fine:
>>http://host/cgi-bin/mapserv?map=/server_path/Apache/htdocs/map_nojoin.map&mode=map&layer=ecozones
>>However, if I comment the 'DATA "ecozones"' line and uncomment the lines
>>referring to OGR, the image displays correctly from a Windows server; so,
>>I'm fairly confident the syntax in the file is fine. But, the same map file
>>(with a different path to the ecozones.shp file obviously) gives the
>>"Premature end of script headers" error.
>>Any pointers as to how I can identify what is causing the error are greatly
>>appreciated. I'm stuck!
> Joanne,
> You might want to try "shp2img" on your map file as it will generally give
> you better error messages. In fact, I usually see specific messages for
> missing shared libraries in my Apache error_log, so I'm surprised you don't
> see more details. Perhaps an old OGR (libgdal.so) is getting picked up
> in your case and this is causing a crash without details.
> Good luck,
