Drawing single point
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu May 18 23:46:02 EDT 2006
This would work assuming the coordinate is in pixels (remove the transform line if in map coordinates):
LAYER
NAME 'my_point'
STATUS DEFAULT
TYPE POINT
TRANSFORM FALSE
FEATURE
POINTS 50 50 END
END
CLASS
SYMBOL 'a_circle'
COLOR 255 0 0
SIZE 10
END
END
To use an annotation layer you'd need to:
- define some text for the feature
- define a label for the class
Steve
>>> Kelly Koehn <knkoehn at HOTMAIL.COM> 05/18/06 8:00 PM >>>
What would be the proper method to draw a single point on a map? I tried to
do a FEATURE and use the POINTS command but couldn't get it to show (in a
new ANNOTATION layer).
I read around that you have to have a symbolset but I couldn't find any
examples of this file's format so I couldn't create one.
Any help would be appreciated!
Thanks!
Kelly Koehn
_________________________________________________________________
Don't just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
