WCS raster output black & white on ECW
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri May 19 08:42:42 EDT 2006
After inspecting the source code I think I know what is going on ... :-)
If ows_extent is set, Mapserver does not inspect the file to get the
extent. So it also does not determine how many bands a file has, and the
number of bands apparently defaults to 1.
If I set wcs_bandcount to 3 and keep ows_extent, it works fine.
Best regards,
Bart
> Just found out after many hours that this is caused by having OWS_EXTENT
> METADATA. If I comment out the OWS_EXTENT metadata, I get the coverage in
> colour.
> Frank, any ideas what could cause this?
> LAYER
> METADATA
> "WMS_LAYER_GROUP" "/LUCHTFOTO/DIGITAAL KLEUREN
> LUCHTFOTOGRAFIE"
> "OWS_TITLE" "Luchtfoto 2005"
> "OWS_ABSTRACT" "Luchtfoto 2005"
> #"OWS_EXTENT" "10000 305000 280000 619000"
> "WMS_METADATAURL_TYPE" "TC211"
> "WMS_METADATAURL_FORMAT" "text/xml"
> "WMS_METADATAURL_HREF"
> "http://145.50.148.28/geoservices/widgets/GeoservicesCatalogSearch/WCASWrapper.php?WCASURL=http://145.50.148.28:8082/deegreewcas/wcas&FILEIDENTIFIER=AAA216"
> "WFS_MAXFEATURES" "50"
> "WCS_LABEL" "Digitale Kleuren Luchtfoto's Nederland.
> Landsdekkende fotografie van Nederland."
> "WCS_RANGESET_NAME" "Luchtfoto's"
> "WCS_RANGESET_LABEL" "Luchtfoto's"
> "WCS_FORMATS" "GEOTIFF,ECW,MRSID"
> "WCS_RESOLUTION" "0.4 0.4"
> "WCS_SIZE" "690000 800000"
> "GML_INCLUDE_ITEMS" "all"
> "GML_EXCLUDE_ITEMS" "class"
> END
> PROJECTION
> "init=epsg:28992"
> END
> NAME "AAA216" # zie basispakket.mdb, ISO19115
> DATA "aerogrid_nl2005/Aerogrid_NL2005_40cm.ecw"
> STATUS ON
> DUMP TRUE
> TYPE RASTER
> UNITS METERS
> MAXSCALE 150000
> END
> Best regards,
> Bart
>> In addition, this is the output when CPL_DEBUG is ON:
>> [Fri May 19 09:05:44 2006] [error] [client 145.50.90.64] ECW:
>> NCScbmOpenFileView(/data/geopakhuis/aerogrid_nl2005/Aerogrid_NL2005_40cm.ecw):
>> eErr = 0
>> [Fri May 19 09:05:44 2006] [error] [client 145.50.90.64] ECW: FileInfo:
>> SizeXY=690000,800000 Bands=3
>> OriginXY=8000,624000 CellIncrementXY=0.4,-0.4
>> projection=LOCAL, datum=WGS84
>> [Fri May 19 09:05:44 2006] [error] [client 145.50.90.64] GDAL:
>> GDALOpen(/data/geopakhuis/aerogrid_nl2005/Aerogrid_NL2005_40cm.ecw)
>> succeeds as ECW.
>> [Fri May 19 09:05:44 2006] [error] [client 145.50.90.64] ECWRasterBand:
>> RasterIO(nXOff=443174,nYOff=749014,nXSize=1254,nYSize=751 -> 1252x750)
>> [Fri May 19 09:05:45 2006] [error] [client 145.50.90.64] GDAL:
>> GDALClose(/data/geopakhuis/aerogrid_nl2005/Aerogrid_NL2005_40cm.ecw)
>> GDALDriver::Create(MEM,msSaveImageGDAL_temp,1252,750,4,Byte,(nil))
>> [Fri May 19 09:05:45 2006] [error] [client 145.50.90.64] ECW:
>> GetGDTProjDat(28992) = NUTM31/RD
>> [Fri May 19 09:05:45 2006] [error] [client 145.50.90.64] ECW: Writing
>> with
>> PROJ=NUTM31, DATUM=RD
>> [Fri May 19 09:06:00 2006] [error] [client 145.50.90.64] ECW:
>> NCScbmOpenFileView(/data/OGC_UMN_services/tmp/ms_tmp/114802234574260.ecw):
>> eErr = 0
>> [Fri May 19 09:06:00 2006] [error] [client 145.50.90.64] ECW: FileInfo:
>> SizeXY=1252,750 Bands=4
>> OriginXY=185270,324394 CellIncrementXY=0.40016,-0.4
>> projection=NUTM31, datum=RD
>> [Fri May 19 09:06:00 2006] [error] [client 145.50.90.64] GDAL:
>> GDALOpen(/data/OGC_UMN_services/tmp/ms_tmp/114802234574260.ecw) succeeds
>> as ECW.
>> GDALClose(msSaveImageGDAL_temp)
>> GDALClose(/data/OGC_UMN_services/tmp/ms_tmp/114802234574260.ecw)
>> GDALDeregister_GTiff() called.
>> Best regards,
>> Bart
>>> Hi list,
>>> using Mapserver 4.8.3, GDAL 1.3.2 final and the latest ECW SDK we are
>>> running into a strange issue. This is on Red Hat Enterprise 3.
>>> We use Mapserver WCS to output rasters in ECW, Geotiff and MrSID
>>> format.
>>> If we use a Geotiff as a source, all output from Mapserver WCS is okay.
>>> If
>>> we use an aerial photo in ECW format as input, all output (ECW, MrSID
>>> as
>>> well as Geotiff) comes out black and white instead of colour. WMS
>>> output
>>> is just fine. Any ideas what could be causing this?
>>> Btw, a direct gdal_translate works fine and outputs in colour:
>>> [root at poseidon gdelivery]# gdal_translate -of "Gtiff" -projwin 185269.9
>>> 324394.4 185771.2 324093.7
>>> /tmp/testbart.tif
>>> Input file size is 690000, 800000
>>> Computed -srcwin 443174 749014 1253 752 from projected window.
>>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>>> These are the output formats used:
>>> OUTPUTFORMAT
>>> NAME "GEOTIFF"
>>> DRIVER "GDAL/GTiff"
>>> MIMETYPE "image/tiff"
>>> IMAGEMODE "RGBA"
>>> EXTENSION "tif"
>>> FORMATOPTION "COMPRESS=PACKBITS"
>>> END
>>> OUTPUTFORMAT
>>> NAME "ECW"
>>> DRIVER "GDAL/ECW"
>>> MIMETYPE "image/ecw"
>>> IMAGEMODE "RGBA"
>>> EXTENSION "ecw"
>>> END
>>> OUTPUTFORMAT
>>> NAME "MrSID"
>>> DRIVER "GDAL/MrSID"
>>> MIMETYPE "image/mrsid"
>>> IMAGEMODE "RGBA"
>>> EXTENSION "sid"
>>> END
>>> This is the gdalinfo output from the source ECW file:
>>> [root at poseidon gdelivery]# gdalinfo
>>> Driver: ECW/ERMapper Compressed Wavelets
>>> Size is 690000, 800000
>>> Coordinate System is:
>>> LOCAL_CS["LOCAL",
>>> UNIT["Meter",1]]
>>> Origin = (8000.000000,624000.200000)
>>> Pixel Size = (0.40000000,-0.40000000)
>>> Corner Coordinates:
>>> Upper Left ( 8000.000, 624000.200)
>>> Lower Left ( 8000.000, 304000.200)
>>> Upper Right ( 284000.000, 624000.200)
>>> Lower Right ( 284000.000, 304000.200)
>>> Center ( 146000.000, 464000.200)
>>> Band 1 Block=690000x1 Type=Byte, ColorInterp=Red
>>> Overviews: arbitrary
>>> Band 2 Block=690000x1 Type=Byte, ColorInterp=Green
>>> Band 3 Block=690000x1 Type=Byte, ColorInterp=Blue
>>> Thanks in advance.
>>> Best regards,
>>> Bart
