pixmap symbol quality question
Didrik Pinte
dpinte at ITAE.BE
Fri May 19 12:06:59 EDT 2006
Le vendredi 19 mai 2006 à 09:43 -0600, Sean Gillies a écrit :
> On May 19, 2006, at 9:13 AM, Didrik Pinte wrote:
> > Didrik
> Didrik,
> Are you using a 256 color output format? If so, it is possible that
> the palette is filled before the symbols are rendered onto the map.
> In that case, GD tries to do its best to find nearest colors from the
> palette.
Hi Sean,
So cool, i've changed the output format IMAGEMODE from PC256 to RGB and
it's really perfect now. I just need to change some white pixels of my
pixmap to transparent.
Many thanks,
Didrik
Name: not available
Desc: Ceci est une partie de message
=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060519/45b84dd7/attachment.bin
