getMap from a WFS
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri May 19 16:33:41 EDT 2006
with the current release, in an ms4w environemt(installed on c:
dirive), the following should work :
IMAGEPATH "c:/ms4w/tmp/ms_tmp"
IMAGEURL "/ms_tmp/"
problems were appearing when the drive was not given. Does your latest
setting (c:\ms4w\Apache\cgi-bin\tmp\) gives the same kind of error message ?
Later,
Christian Wilmes wrote:
> Thank you for the hint. But is there now a possibility to solve the problem or isn't it yet?
> I tried out something like this but it doesn't work:
> IMAGEPATH "c:\ms4w\Apache\cgi-bin\tmp\"
> IMAGEURL "/cgi-bin/tmp"
> -------- Original-Nachricht --------
> Betreff: Re: [UMN_MAPSERVER-USERS] getMap from a WFS
> Datum: Fri, 19 May 2006 11:23:13 +0200
> Von: "Bart van den Eijnden (OSGIS)" <bartvde at XS4ALL.NL>
> An: MAPSERVER-USERS at LISTS.UMN.EDU
>>See:
>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1770
>>Best regards,
>>Bart
>>>Hi All,
>>>I want to make a getMap-Request on my own WFS but get the following
>>error:
>>><ServiceException>msDrawMap(): Image handling error. Failed to draw
>>layer
>>>named 'RosoftWFS'. msOGRFileOpen(): OGR error. Open failed for OGR
>>>connection `/tmp/\a3cee2f593a1a7016aec7da4cfaaa8cd.tmp.gml'. File not
>>>found or unsupported format.</ServiceException>
>>>I think, that something with the Imagepath / Imageurl in my WFS is not
>>OK
>>>The mapfile for WFS is in c:\ms4w\wfs.map
>>>Here is the WEB-Section of the mapfile:
>>>WEB
>>> IMAGEPATH "\Apache\cgi-bin\tmp\"
>>> METADATA
>>> "wfs_title" "WFS Server"
>>> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?"
>>> "wfs_srs" "EPSG:4326"
>>> END
>>> END
>>>>Has anybody an idea how I can fix the error?
>>>Best Regards
>>>Christian
>>>>Bis zu 70% Ihrer Onlinekosten sparen: GMX SmartSurfer!
>>> Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
