about the Apache error.log file.
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon May 22 05:05:41 EDT 2006
Mapserver also logs debug info to the Apache error log, or any other file
you specify with MS_ERRORFILE.
This only happens if DEBUG is set on your MAP or LAYER objects.
So if you don't want it, remove the DEBUG statements from your MAP file.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens
Zhonghai Wang
Verzonden: maandag 22 mei 2006 10:55
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] about the Apache error.log file.
Hi guys,
if I open the error.log file in the Apache Logs folder, there is some info
like this:
>>>[Mon May 22 10:44:35 2006] [error] [client 127.0.0.1 <http://127.0.0.1> ]
msDrawMap() total time: 1.031s\r
which means there is an msDrawMap() error occurs, but actually the map image
is successfully returned to the web browser, and it takes only 1.031 second.
why does this error message appear? a mistake from MapServer or something
really happened?
thanks for any info.
zhonghai
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060522/dfc6e557/attachment.html
