gdaltindex raster files (MapInfo gif + tab format) {Scanned}
{Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue May 23 11:06:04 EDT 2006
You must create world files from mapinfo tabs.
I could do it by an awk script, but my case was special.
Nonearth coordinates and the four corners were given in the tab files and
no rotation.
^ y
|3 4
+----------+ ------> x
1 2
tab file contains raster coordinates like (0,0) for point 3 and the world
coordinates.
you can get the first row in the world file:
(x2 - x1) / (col2 - col1) called dx
The second and third rows are zeros if no rotation
fourth row
(y3 - y1) / (row3 - row1) called dy (it is always negative)
the last two rows are the x,y coordinates of the center of the top-left
pixel
x3 + dx / 2
y3 + dy / 2
I hope this helps you
Zoltan
On Tue, 23 May 2006, Zhonghai Wang wrote:
> Hi guys,
any further ideas for this topic?
l am really overwhelmed by it.
since I have a amount of small GIF+TAB files, if I really need to create
worldfiles for all the GIFs, it will be a huge project and seems not be
possible.
thanks a lot for any idea I can try.
zhonghai
On 5/22/06, Zhonghai Wang <zhonghaiw at gmail.com> wrote:
> Hi,
> I've checked using "mapserv -v" and the GIF is supported.
> but it's strange that I can not performed "gdalinfo --formats" or
> "gdal-congif --formats" to check if the GIF format is supported. I am using
> the precomplied MS4W on WinXP. Does this mean that my gdal utility is not
> really working? but I still can use some commands such as "gdalinfo" and
> "gdal_translate".
> zhongahi
> > Hi guys,
> > I get some info again from the "Raster Dat Access" document, and it
> > indicates that:
> > GIF: If GD is configured with GIF (OUTPUT=GIF) support, then MapServer
> > will also be able to read GIF files for raster layers. The only way to
> > georeference GIF files is with a world file.
> > If GD is not configured with GIF support, it may still be available in
> > GDAL
> > Is it true that GIF raster images can only be georeferenced with a
> > worldfiles? TAB files are not supported?
> > zhonghai
> > On 5/22/06, Zhonghai Wang <zhonghaiw at gmail.com > wrote:
> > > Hi guys,
> > > I've found a way to do that, like this:
> > > c:\.....rasterdata>dir /b /s tem\*.gif > index.txt
> > > c:\.....rasterdata>gdaltindex index.shp --optfile index.txt
> > > and this works well.
> > > but georeferencing information in the TAB file can not be found by the
> > > command, an error message is something like:
> > > >>>no georeferencing info is available, gdaltindex performance will be
> > > skipped.
> > > actually there is georeferencing info in the TAB file, for each small
> > > gif image there is a corresponding TAB, e.g.:
> > > !table
> > > !version 300
> > > !charset WindowsLatin1
> > > Definition Table
> > > File "m_1_1_1000.gif"
> > > Type "RASTER"
> > > (5.290517,48.2308475) (1392,987) Label "Pt 1",
> > > (5.25001439194036,48.25) (0,0) Label "Pt 2",
> > > (5.25001439194036 ,48.211695) (0,1974) Label "Pt 3",
> > > (5.33101960805964,48.25) (2784,0) Label "Pt 4",
> > > (5.33101960805964,48.211695) (2784,1974) Label "Pt 5"
> > > CoordSys Earth Projection 1, 104
> > > Units "degree"
> > > why can it not be read by gdal?
> > > thanks a lot
> > > zhonghai
> > > On 5/22/06, Mateusz Loskot <mateusz at loskot.net > wrote:
> > > > Rahkonen Jukka wrote:
> > > > > Very first you can try giving the full path to your images, I mean
> > > > > c:\...\rasterdata\tem\*.gif. Let's see what happens.
> > > > It should not be the case.
> > > > I've checked gdaltindex from latest FWTools on Windows and
> > > > it works with relative and absolute paths.
> > > > Also, you can use forward or back slash:
> > > > gdaltindex test.shp data/*.tif
> > > > gdaltindex test.shp data\*.tif
> > > > Although, gdaltindex usage message suggests to use the former
> > > > version
> > > > with Unix-like forward slash.
> > > > Cheers
> > > > Mateusz Łoskot
> > > > http://mateusz.loskot.net
