shapefile with z and m values
Frank Warmerdam
warmerdam at POBOX.COM
Tue May 23 10:30:23 EDT 2006
Stuart Eve wrote:
> Mauricio
> You can read in those shapefiles using the OGR driver:
> CONNECTION "/path/to/shapefile.shp"
> CONNECTIONTYPE OGR
> That should read in shapefiles with z and ms
Andres,
Stuart's suggestion should get you around such a problem.
> Andres Mauricio Ramirez wrote:
>> Hi List
>> I have a shapefile with z and m values, mapserver don't show me the
>> map, can mapserver read that?
But in general, MapServer should be able to read shapefiles with
z and m and just drop the extra portions of the coordinate if things
are not configured for z/m support.
If this is not the case, and you are using MapServer 4.8.3, then please
submit a bug report with test data and a test map that we can use to easily
reproduce the problem.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
