Help needed with compiling postgre sql with mapserver
rock well
rockwell_001 at YAHOO.COM
Wed May 24 17:28:09 EDT 2006
Thanks for your reply fleuren, yes i did the same way you told but still it give the following errors
LINK : fatal error LNK1181: cannot open input file "shfolder.lib"
NMAKE : fatal error U1077: 'link.exe' : return code '0x49d'
Do you know why we get these errors, or else all we need is i guess the libpqdll.lib and some dlls right, if anything doesnt work can you send me those dlls.
Thanks verymuch for your help and time ...
kris
Huub Fleuren <hfl at home.nl> wrote:
Hi Rock,
i recently compiled postgreql-8.1.3 with vc6sp4 and
5.2.3790.2075.51.PlatformSDK_Svr2003R2_rtm.img
(install from virtual CD)
first vcvars32
then setenv
then nmake /f win32.mak
after a failure you always do nmake /f win32.mak clean
Regards, Huub
rock well schreef:
> Hi all, i am trying to compile mapserver with postgre sql support. I
> found this documentation in the mapserver website
> http://mapserver.gis.umn.edu/docs/howto/win32_compiling
> I downloaded the MS platform sdk and installed it, when i try to run
> the win32.mak file in the libpq directory it still says
> the shfolder.lib does exist in the the default MS platform sdk folder,
> do i have to change something or am i doing something wrong ...
> Thanks for your time ....
> kris
> Blab-away for as little as 1¢/min. Make PC-to-Phone Calls
> using Yahoo! Messenger with Voice.
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060524/7e7e527f/attachment.html
