CGI MapServer, Dynamic Points
Fischer, Brian
bfischer at HOUSTONENGINEERINGINC.COM
Fri May 26 21:58:12 EDT 2006
Chip,
Check out ovf in ogr. http://mapserver.gis.umn.edu/docs/reference/vector_data/VirtualSpatialData That is the way I am displaying points from a MS database. Works very well. I think I've posted the layer snippet and .ovf file a while back on the list, if you search the archives you might be able to find it. If not let me know and I get dig it up.
Hope this helps,
Brian
From: UMN MapServer Users List on behalf of Chip Hankley
Sent: Thu 5/25/2006 11:04 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] CGI MapServer, Dynamic Points
I'm trying to use CGI MapServer (ie NOT MapScript) to dynamically add
points to a map based on X and Y fields in a database (currently MS
Access). Can someone point me in the right direction?
MapServer 4.8.3
Windows, IIS
TIA -
Chip Hankley
RMT, Inc.
chip.hankley at rmtinc.com
608.662.5498 (Direct)
Outgoing messages, along with any attachments, are scanned for viruses prior to sending.
NOTICE--This email may contain confidential and privileged information
for the sole use of the intended recipient. Any review or distribution
by others is strictly prohibited. If you are not the intended recipient,
please contact the sender immediately and delete all copies.
