JavaMapscript SIGSEGV
Andre Sachs
asachs at CLUE.CO.ZA
Sun May 28 12:44:22 EDT 2006
Hi Everyone,
I have problem with the java Mapscript library. I have a servlet that
displays a map without problems. When I go after any kind of shapeObj
the trouble starts. The following short java program causes a SIGSEGV
error :
import edu.umn.gis.mapscript.*;
public class Test {
public static void main(String[] args) {
shapeObj s = new shapeObj(mapscript.MS_SHAPE_LINE);
The error that is produced :
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00002aaaaae43d5b, pid=23120, tid=46912501734144
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_06-b05 mixed mode)
# Problematic frame:
# C [libc.so.6+0x67d5b]
# An error report file with more information is saved as
hs_err_pid23120.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Aborted
And the environment that the error is occuring in is :
Linux icarus 2.6.15-gentoo-r7 #1 Sat May 6 19:49:25 SAST 2006 x86_64
AMD Athlon(tm) 64 Processor 3800+ GNU/Linux
java version "1.5.0_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_06-b05, mixed mode)
Has anyone else deployed on a 64 bit platform ? Is there some magic I
am missing ?
Kind regards,
Andre Sachs
Andre Sachs
IT Architect, Clue Technologies PTY (LTD)
email: andre at clue.co.za
