JavaMapscript SIGSEGV
Oliver Lichte
lichte at ICBM.DE
Mon May 29 03:25:23 EDT 2006
Hi Andre,
is it really the case for libs in /usr/lib like libgd.so?
file on libpng on my machine returns this differing
file /usr/lib/libpng.so.3.1.2.8
/usr/lib/libpng.so.3.1.2.8: ELF 32-bit LSB shared object, Intel 80386,
version 1 (SYSV), stripped
file /usr/lib64/libpng.so.3.1.2.8
/usr/lib64/libpng.so.3.1.2.8: ELF 64-bit LSB shared object, AMD x86-64,
architecture:
Linux labrador 2.6.13-15-smp #1 SMP Tue Sep 13 14:56:15 UTC 2005 x86_64 x86_64
x86_64 GNU/Linux
Afaik you will need the 64-bit version of libgd and others.
Regards,
Oliver
Am Sonntag 28 Mai 2006 21:41 schrieben Sie:
> On 28 May 2006, at 9:22 PM, Oliver Lichte wrote:
> > Hi Andre,
> > is it possible that your native JavaMapserver binaries are not
> > linked against
> > 64-Bit libraries?
> Hi again Oliver,
> Just checked all the linked libraries using the file utility and it
> reports they are all 64 bit, including libmapscript.so itself.
> I suspect that this is not the answer that you wanted :)
> Thanks and regards
> Andre
> Andre Sachs
> IT Architect, Clue Technologies PTY (LTD)
> email: andre at clue.co.za
Nachwuchsforschergruppe IMPULSE
Institut für Chemie und Biologie des Meeres (ICBM)
Carl-von-Ossietzky-Straße 9-11
Postfach 2503
D-26129 Oldenburg
www.icbm.de/impulse
www.icbm.de/anemos
Tel.: +49-441-798-3622
Fax : +49-441-798-3404
Mail:lichte at icbm.de
IMPULSE is also involved in the European project POWER
Pushing Offshore Wind Energy Regions
See the POWER Website: www.offshore-power.net
