mapserver and selinux
Micha Silver
micha at ARAVA.CO.IL
Tue May 30 08:33:48 EDT 2006
I've setup mapserver-4.8.3 on a CentOS-4.3 server. With SELinux enabled
I can't get mapserv in /var/www/cgi-bin to work. It can't find libpq.so.
Running ldd on the mapserv binary in the original compile location
returns OK:
[root at maps ~]# ldd /home/micha/download/mapserver-4.8.3/mapserv | grep libpq
libpq.so.4 => /var/lib/pgsql/lib/libpq.so.4 (0x0072d000)
But running ldd on the *same* binary copied to /var/www/cgi-bin:
[root at maps ~]# cp /home/micha/download/mapserver-4.8.3/mapserv
/var/www/cgi-bin/
[root at maps ~]# ldd /var/www/cgi-bin/mapserv | grep libpq
libpq.so.4 => not found
The copy has selinux context:
[root at maps ~]# ls -Z /var/www/cgi-bin/mapserv
-rwxr-xr-x root root root:object_r:httpd_sys_script_exec_t
and indeed in the messages log there are "audit:...avc: denied" errors
for mapserv:
May 30 14:11:11 maps kernel: audit(1148987471.254:2): avc: denied {
read write } for pid=2662 comm="mapserv" name="0" dev=devpts ino=2
scontext=root:system_r:httpd_sys_script_t
tcontext=root:object_r:initrc_devpts_t tclass=chr_file
May 30 14:11:11 maps kernel: audit(1148987471.254:3): avc: denied {
use } for pid=2662 comm="mapserv" name="0" dev=devpts ino=2
tcontext=user_u:system_r:initrc_t tclass=fd
May 30 14:11:11 maps kernel: audit(1148987471.254:4): avc: denied {
May 30 14:11:11 maps kernel: audit(1148987471.255:5): avc: denied {
read } for pid=2662 comm="mapserv" name="libpq.so.4" dev=sda2
ino=1423567 scontext=root:system_r:httpd_sys_script_t
tcontext=root:object_r:var_lib_t tclass=lnk_file
May 30 14:11:11 maps kernel: audit(1148987471.331:6): avc: denied {
If I drop the seliux level to "permissive" (logs error but doesn't deny)
then mapserv works as expected.
Can anyone suggest how to set this up, short of disabling selinux??
Thanks, Micha
Micha Silver
Arava Development Co
+972-8-6592270
