Problem: ANGLEITEM and TRANSPARENT
Christian Wilmes
C.Wilmes at GMX.DE
Tue May 30 09:11:39 EDT 2006
Hi All,
I'm trying to visualize point-data with the mapserver. As symbol I'm using a transparent PIXMAP. Now I want to use ANGLEITEM in the STYLE-Object, ANGLEITEM itself is working fine, but using it causes the lost of the transperency. Instead of the parameter TRANSPARNZ in the SYMBOL-Object I also tried it with a gif and a png which has already a transparent background. The result is the same, without ANGLEITEM it works fine but without it doesn't.
Does anybody have an idea how to fix that problem?
Best Regards
Christian
Bis zu 70% Ihrer Onlinekosten sparen: GMX SmartSurfer!
Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
