Make points on a map clickable + use criteria from MySQL
Mike D'Ambrogia
miked at JAMAGINATION.COM
Tue May 30 13:17:22 EDT 2006
How would you determine which point you were looking at off the
imagemap?
-----Original Message-----
One way to do this is with an imagemap that calls a javascript function
it add the item to an array. Then you can fetch and use the array of
items for whatever later.
-Steve W
Sarah Parrott wrote:
> Hi,
> Is there a way to make points on a map clickable? Basically I want
> the
> user to be able to look at the map and then select a subset of the
> points on it by clicking on them and then use this 'list' of points
> somewhere else. The points are stored in a shapefile which is
displayed
> on top of a raster layer.
> Also, with the same points in the shapefile, can I display them
> differently depending on a value in a mysql database? Each user will
> have their own data about that point - mainly whether or not they have
> been there - and I want to be able to show points they have visited in
a
> different way to points they haven't.
> Thanks!
> Sparrott :)
